09-20-2009
The Builder's plate will have the 'Max Capacity' of weight that the boat will carry safely.
Needless to say: If that plate says that the Max is 700 lbs... that means you better be aware of how much you and your crew weight, the weight of your groceries and other ancillary equipment that you have on board.
One example: A 15 ft boat's builder's plate stated that 700 lbs was the max.
The owner and two of his friends (all weighting over 250 lbs each) wanted to go fishing. So they loaded the boat up with their fishing tackle, a couple of coolers with their groceries and beer, and a new heavier outboard engine that exceeded the recommend HP for that boat. Anyway they launched the boat and proceeded out onto the Willamette River. Not noticing that their gunnel was inches from the water and the outboard mount slot only had an inch or two from the water. Needless to say when the low wake of passing tugs swamped this overloaded boat. No lifejackets; two drowned trying to swim to shore and the one hanging onto the overturned boat suffered from hyprothermia.
Lesson!? Read the builder's plate and stay inside the Max weight allowed.
1600 Ton Master, 2nd Mate Unlimited Tonnage
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Maritime Instructor To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
S/V Rapture
