-   -   contol lines mainsail, lancer 30 (http://www.sailnet.com/forums/general-discussion-sailing-related/5835-contol-lines-mainsail-lancer-30-a.html)
shynrbok 12-19-2002 09:16 AM
I have been sailing smaller sailboats most of my adult life, i.e, lasers, hobies etc. I just inherited a lancer 30, 1985 model. After re-stepping the mast and attaching the boom, I started to rigg the mainsail. Here is the problem. There are 3 control lines 1 port, 1 center, and 1 starboard that run through the boom which are not attached to anything yet. How can I know for sure which goes where and controls what? Suggestions/opinions.
Thank you,
GG
Irwin32 12-19-2002 10:53 AM
I am wondering if one is an outhaul, and the other two are reefing lines. The reefing lines would be attached through stainless rings sewn or pressed into the leech of the main. One would probably be about 2 feet or so up from the clew, while the second ring would be another couple of feet above that. These become the clew when you are reefed. There should be corresponding rings sewn into the luff, which become the new tack when reefing. These lines are probably run through the boom going forward where they would exit to turning blocks, maybe at the mast step, and run back towards the cockpit, typically passing through line stoppers which are used so that 1 winch can be used for several functions.
It is possible on a 30 footer, that the reefing lines exit the boom mid cockpit and you just use brute force when reefing at the clew. In this case you would find some cleats mounted on the boom near the exit slots.
It is also possible this main has three reef points, though two is more common.
Jeff_H 12-20-2002 03:21 PM
More likely than not, the center line is the outhaul and has a tackle in the boom to give you greater machanical advantage and the two outboard lines are clew reef lines for a slab reefing system. The reef lines run from the end of the boom, through the reef cringle and then are typcially tied around the boom at a point aft of the reef cringle in the reefed position.
