Any Albin Nimbus 42 owners out there - Page 4 - SailNet Community
 4Likes
post #31 of 97 Old 12-09-2012
Senior Moment Member
SloopJonB's Avatar
Re: Any Albin Nimbus 42 owners out there
Originally Posted by hellosailor View Post
My understanding is that it is not "foam" but a curly plastic material more like a coarse version of a Scotchbrite pad. It is not a foam rubber or anything like that, and should not degrade when wet, as the water will simply run through it. I haven't been into one to see what it actually is, but heard it repeatedly in reviews, etc.
Sounds like those "breather" pads for under berth cushions.
SloopJonB is offline
post #32 of 97 Old 12-09-2012
Yes, and they are all properly known as "geotextiles". Invented IIRC by Phillips Petroleum one of the other Seven Sisters as a road underlayment material. In the early 60's there were plans to build the big PanAmerican Highway by having huge six-lane wide machines cut and level the forest, lay underlayment for road drainage, pave it over, and leave six lanes of highway behind the machine as it ran from the north down to Tierra Del Fuego.
My, haven't we lowered our expectations.
This is all the same road underlayment, still used as a geotextile material for drainage in landscaping. The stuff under bunks is just a very expensive slice from the same big roll at the gardening supplier.
The stuff that 3M made popular for scrubbing pads, supposedly comes from 3M's great culture. Someone left a piece in the group kitchen, someone else started using it as a pot scrubbing pad, voila, millions to be made by encouraging different departments to eat and play together.
hellosailor is offline
post #33 of 97 Old 12-09-2012
SloopJonB's Avatar
That IS part of 3M's culture - thinking outside the box. The Post-It note is a great example - a "failed" adhesive that became a ubiquitous product.
post #34 of 97 Old 12-09-2012
From what I have seen of the foam in our boat, it was not quite 3m scrub pad, but more like the green foam block used in flower center pieces. It sure does let water run though.
Watchcap, Feel free to drop me a line at talonawd1991 at yahoo dot com.
talonawd91 is offline
post #35 of 97 Old 12-09-2012
baDumbumbum
bobmcgov's Avatar
Yeah, that's it. Here's a couple core samples taken today from our 1972 Albin Ballad:
cores
The one on the right is from just in front of the seahood. It is dry and well-adhered to the skins. The one on the left is from near the port side chainplates, which have probably been leaking for twenty years. The foam is damp to the fingers when squuezed, and it isn't particularly well-stuck to the skins.
But the side decks don't flex, and as long as the foam keeps the skins apart from each other, the essential strength of the core-box design remains. The decks do not flex when you walk on them. And the wet foam has not turned to slurry as balsa often does. It is still quite rigid. I suspect Albin made the outer skin so stout, the core and inner liner are almost optional.
Buccaneer18, Grainnia
SJ21, Diarmuid
Albin Ballad 30, Fionn
bobmcgov is offline
post #36 of 97 Old 12-09-2012
SloopJonB's Avatar
cores
Looks like CoreCell foam. I've used it in the past. Expensive but good stuff - very rigid and difficult to compress, even with very localized pressure on the bare foam. Except for the cost, I would use it in a heartbeat over balsa.
post #37 of 97 Old 12-09-2012
baDumbumbum
bobmcgov's Avatar
Very like CoreCell -- probably a direct ancestor. Slightly different texture (I recored our SJ21 with CoreCell, and like you, I think it better than balsa.) It's definitely a closed cell urethane of some kind. On the Ballad, the core is a full 1" thick. Which seems like total overkill, but I'm okay with that.
This boat lived in the Great Lakes for probably most of its life. Despite many freeze-thaw cycles, the wet foam has generally not caused any deck problems. I'll still recore where appropriate, but I'm not going to sweat every last square inch of wet decks. Three years in Wyoming and five more in the Sonoran Desert ought to dessicate things nicely.
SloopJonB likes this.
SJ21, Diarmuid
bobmcgov is offline
post #38 of 97 Old 12-14-2012
baDumbumbum
bobmcgov's Avatar
Final note on Albin deck cores. I've since learned the core material is Divinycell, a high-density PVC foam. Still made and available in Europe and North America. The plug I removed was 1.77 cubic inches of foam. The foam weighed 14g wet (30+% MC)at removal; in less than five days in a warm house, it has stabilized at 4g and 6-% MC. Upshot is, if you expose the core & keep the ambient RH low, your foam will go back to factory-dry in jig time. Despite undergoing many freeze-thaw cycles in the upper Midwest, the foam is structurally very sound & resistant to compression. So wet decks on Albin boats are less of a deal-killer than they might be on other marques. Cheers.
SJ21, Diarmuid
bobmcgov is offline
post #39 of 97 Old 01-04-2013
Any of you guys owning a nimbus out there able to take a photo of the helm steering setup down below, and of the mechanisms that hold the engine hatch on? My helm had been removed but the sheaves, quadrant, and such are still there, but they look unoriginal. My engine hatch was glued down and missing what I assume was hatch locks. Any help would be very appreciated.
post #40 of 97 Old 01-10-2013
Hi, another new nimbus owner here. Just bought Veela, formerly Sherry Dawn. Who knows something about this boat? It just got new decks, but needs TLC
Albin42 is offline
experience, analysis, opinion: 26ft Albin winslow59 Boat Review and Purchase Forum 4 07-26-2015 06:39 PM
Albin O-22 Aux. Engine Owner''s Group Forming owenmccall Gear & Maintenance 3 11-22-2009 11:58 AM
Albin Marine Nimbus 42 MGFraser Boat Review and Purchase Forum 9 08-10-2008 12:36 AM
Albin Nimbus 42 gstraub Boat Review and Purchase Forum 1 10-16-2002 03:41 PM
