10-12-2009
Tartan 27' owner
There are 3 ways you can go faster then 'hull speed' that I can think of.
1 - sailing in a following sea where the waves are big enough to surf. You will experience an increase in speed as the boat surfs each wave.
2 - sailing with a current. In the East River and other tidal canals (Cape Cod, D/Chessy) the current will add significantly to your speed over ground (SOG).
3 - in the right conditions sailing with a spinnaker can push the limit of the theoretical 'hull speed'.
Most of the time though you would be happy to get 5+ knots on a CD 25.
If you really want faster then consider a planing hull, longer boat (LWL), or a catamaran or tri (or powerboat).
