10-23-2009
Assuming you want the volume, the number that you are looking for is the gross tonnage. Commercial vessels will actually state their tonnage as required by law (they include net tonnage as well which is the cargo carrying capacity of the hull, not the total volume). If the boat that you are looking at does not have a published gross tonnage number, then you can get an approximate idea from the formulas that the CG uses. I don't have them with me right now but a quick internet search should help. The inputs are length, beam, draft, vessel type if I remember right. If a ton isn't a unit that you can visualize, it is straight forward to convert it into cubic feet or gallons or another unit.
