10-24-2009
Moving the mainsheet further aft is simpler than moving it forward, as moving it aft reduces the loads on the mainsheet and the boom. You will probably need a different traveler, if you have to span the cockpit.
The photo faster was talking about is this:
You'd need to have some fairly hefty backing plates for the traveler...and I don't know if the cockpit seats are strong enough to handle the loads without modification.
