- Quick Menu
06-29-2010
My friend says something similar about his boat, except it goes like this:
Sails SIX
Feeds FOUR
Sleeps TWO...
Drinking aboard, at least while underway, is heavily frowned upon. Alcohol reduces your night vision, makes your judgement suspect, your reflexes slower and less coordinated, and increases your risk of dehydration and seasickness.
Originally Posted by swimnfit
Came accross this thread and while old found it interesting and thought I would throw my two cents in as well
My perfect boat "tongue in cheek"
Drinks six
eats four
sleeps two
sailed by one
06-29-2010
Sailed by one:
Brian
06-30-2010
48' wood S&S yawl
Well, with all this talk about metal boats, were I to build in metal (I probably wouldn't- I'd stick with wood). I'd go with a cupronickel hull- There's a couple out there that seem to have been problem free.
But if new: Angelique hull, balata frames and keel, wana deck, all monel fastened.  Yawl rigged with aluminum sticks- probably go a little smaller too -high 30's LOA.
"Never attribute to malice that which can be adequately explained by stupidity." - Robert A.Heinlein
06-30-2010
Bombay Explorer 44
The one I have just now does very nicely thank you. A New Bombay Trading Company [ Yes that is the builders name ] Explorer.
44ft Don't think I can handle anything larger in comfort.
BIGGEST shower I have ever seen on ANY boat. Even Travis would be impressed!
Draws 5.6 with the board up.
Fairly fast for a cruiser.
Great cockpit for Caribbean living
If the numbers come up I am not sure that I would change her for something else, just pay some one to paint her exterior which needs doing sometime soon.
06-30-2010
Originally Posted by zz4gta
It's not the cost of the boat, or sail inventory, I just can't seem to find 11 friends to sail it with me. Yeah, that's it...
Thanks for the wallpaper
For me, my contessa 26 but 2-3 feet longer with a limited amount of standing headroom and a little heavier built. Strong and still easy to handle solo but with enough room that I don't feel like I am in a shoe box when below.
John
p.s I would pay good money to crew on the above boat, you can keep your ferrari, I'd settle for the keys to the above.
The keys to a gsxr1100 and a cop free open/twisty road or the above boat, that would be a tough call, but I digress....
06-30-2010
John
On the water, that is a Ferrari!
Brian
07-15-2010
Annapolis, MD
Requirements:
- Ocean-capable
- 34 to 36 ft
- PHRF rating less than 100
- Single-handable (Main traveller in cockpit, Roller Fuller, Jib Winches Reachable from helm)
- Less than 5 ft Draft with Fixed Keel
- Teak Interior/Aft Stateroom/Nav Station/Full Galley/LP Stove & Oven/Refrigeration/AC
- Updates Electronics (AIS, Sailing Instruments, Chartplotter at Helm)
- Inverter/Charger/Battery Monitor/High-Output Alternator/2 House & Dedicated 3rd Cranking Battery)
- Laminate Performance Cruising Sails
- Head with Full Shower & Cockpit Shower/Hot & Cold Pressure Water
- Minimal Exterior Teak
07-15-2010
Originally Posted by jmarquez
Requirements:
- Ocean-capable
- 34 to 36 ft
This is all very specific and must be part of the boat's original design IMHO. You can't really retrofit much of this.
Most of this stuff can be retro-fitted onto a boat to some degree...
The draft, PHRF rating and Ocean-capable are going to be the issue, since most cruising boats in this size range aren't going to rate all that well.
For instance, the J/35 fails several of the requirements like draft, aft cabin, etc.
All boats are compromises, and you will probably have to give something up to get a boat that satisfies most of your requirements.
You'd also be far better off starting your own thread on this topic... If you haven't, I highly recommend you read the POST in my signature to help you get the most out of sailnet.
07-15-2010
Requirements:
- Ocean-capable
- 34 to 36 ft
Like this one?
RM YACHTS | RM 1060
The previous model is a favorite among young French long distance cruisers. That's a bluewater boat with lot of transats and probably circumnavigations.
RM YACHTS | RM 1050
I now that this boat has 1.6 draft and that works with so little because it is a sharp twinkeel. For having the same performance with a normal keel it is nedeed 1.9 draft. If you have really a nead for less than 1.5, you will need a boat with a lifting keel, or you will not have a boat with a very good performance to windward.
| Thread Tools |
Search this Thread |
