mooring needed Maryland, Carolina: 6 months - SailNet Community
Blogs
Old 11-02-2009
ramminjammin is on a distinguished road
like the title says, need to store a boat
Old 11-02-2009
FormerTripper is on a distinguished road
Do you want to keep in down here in Annapolis?
Old 11-02-2009
further south the better
Old 11-02-2009
scottyt is on a distinguished road
the chessy has the best rules for mooring and anchoring, stay out of channels oyester bed, cable areas and the severn river and its pretty much do as you want. the worse part is annapolis and kent county are the only ones that require permits.
there is a marina in the rhode river area that has mooring for rent, i have seen adds for them on craigslist
Old 11-03-2009
Jeff_H's Avatar
Super Moderator
If you are on a mooring you will not be able to check on the boat for roughly a month in winter when the creeks that are shallow enough for moorings are frozen. Also, mooring for the winter can be pretty risky since holding on the Chesapeake is not all that great and the ice flows can come through and cut most mooring lines and simply drag off the a moored boat.
Depending on the width and draft of your tri, I may be able to let you tie up in the slipway at my home.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 11-03-2009
klem is on a distinguished road
Is storing the boat out of the water not an option? It just seems like you would have to worry a lot less and it would be easier for you to prep the boat in the spring for your trip back home.
Old 11-03-2009
You might want to contact some of the members who have private docks down on the Chesapeake, rather than moorings, as moorings are going to be far more risky.
It would help if you gave more specifics about the boat, such as the draft, beam, make, model, etc.
Mediterranean Mooring John Kretschmer Seamanship Articles 0 12-22-2003 08:00 PM
The Mechanics of Mooring Mark Matthews Seamanship Articles 0 05-19-2002 09:00 PM
Mooring advice needed dscottl General Discussion (sailing related) 12 04-25-2002 03:59 PM
Mooring RobGallagher General Discussion (sailing related) 4 03-02-2002 05:59 AM
Volvo Ocean Race—Six Months and Counting Dan Dickison Racing Articles 0 04-01-2001 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
