11-13-2009
go for it
The fact that your considering do it yourself tells a lot. Most people that don't no what to do shouldn't try it. (that would include the nay sayers) Go ahead and hammer me.
I've done what your planning. Everyone has added good thoughts. I went through eight states and 2500 miles, never bought a permit and no one questioned me. I did have proper signs and flags. I did my move after getting the run around with movers and yards finally realizing I was probably more qualified to do a safe and sane move. Keep your final height below 13' 9" and stay on the interstates to avoid problems. When I made the cradle I used scaffold leveling jacks and lots of water pipe, bits of angle and 1/2 inch bolts.. You should put 50% of the weight on the keel, the rest on the supports. I used four on each side and one under the bow below the water line. The bow one is very important to absorb the shocks, I would not skip it. Bring a really big bottle jack and a spare just in case, repack your bearings, check your brakes, and your good to go.
BTW I would rent or hire a boom truck to load the first time so that you get the tongue weight correct, six inches for or aft can make for 1900 miserable miles. TJ
