11-09-2009
Moderator
Andrew,
Some boats use runners only occasionally, in heavy going, to help stabilize the mast and resist pumping. This is especially true on boats that fly an inner forestaysail (such as cutters). Our rig, for instance, is designed to use runners when a heavy air 'staysail is in use. But we don't even have the runners rigged because we don't need them for the kind of sailing we do.
However, on some boats, the running backstays are not optional and must be used at all times, since they are the primary aft support for the mast. This is the case on many fractionally rigged designs -- including many that were also rigged with a "tuning" backstay.
In general, I would not recommend running backstays for short-handed sailing if the runners are the primary backstay for the mast. It is an extra bit of choreographing that most of us could do without when tacking and jibing. On crewed boats, it's less of an issue.
What I'd want to know in your case, was were the runners an essential part of the rig support, and a previous owner took a risky shortcut by eliminating them? If so, did they beef up the backstay and/or the mast to compensate for a different standing rigging geometry? Etc?
P.S. There really aren't any advantages to running backstays, at least for most of us. On gaffers, they were a necessity, but todays modern rigs, even most of the fractionally rigged boats, have done away with them (except as noted above for heavy air).
Reason: added p.s.
