Tiller holder - Page 2 - SailNet Community
post #11 of 16 Old 02-26-2010
tager's Avatar
I don't know. The cajun setup is pretty corrosion proof too. Cheaper. It has multiple uses (line.) The cajun setup is cheapest. The cajun setup has simplicity on its side. I like it.
tager is offline
post #12 of 16 Old 02-26-2010
NON member
AE28's Avatar
Using bungee cord for the tiller tamer also allows for immediate release - just slide it off the end of the tiller.
Paul
AE28 is offline
post #13 of 16 Old 02-26-2010
tager's Avatar
The cajun has immediate release, just slide her aft.
tager is offline
post #14 of 16 Old 02-26-2010
For flag halyards, one can buy a shroud cleat. It's made out of aluminum and stainless and doesn't do your shroud any favors.
Or, one can take a cheap little plastic cleat, groove out the bottom with a Dremel to accept the wire and seize it on with some waxed twine. Both will work just as well.
For hanging fenders, one can buy a plastic clip thing that you tie your line to and then hang on the lifelines.
Or, one can just tie directly to a shroud, hand rail, toe rail, genoa car or stanchion base.
You won't bend your stanchions, loosen the bolts and create leaks if you don't hang crap on your lifelines.
I love using line for things that other people feel they need to buy little metal and plastic things to do.
I really like the Cajun thing too, but only in certain conditions.
I was hove to or extremely close hauled in heavy seas for a period of 5 days once and the tiller comb that was holding my tiller never slipped once.
As much as I love knots, there is no way that the Cajun thing could do that.
What you make, buy, and ultimately use for taming your tiller, as well as every other system on the boat, depends on how you want to use the boat and how trouble free you want it to be.
knothead is offline
post #15 of 16 Old 02-26-2010
Tiller combs are a great if old-fashioned solution. I would use one but I have an autopilot... and if I need to just hold the tiller...I just use the autopilot, but leave it turned off...
sailingdog is offline
post #16 of 16 Old 02-26-2010
tager's Avatar
Davis Fender tender. Yeah those things are a joke. As well as those wire bolts, which squeeze the shroud to attach things to it. Ugh I hate those. The cajun probably wouldn't work to lock the tiller in a storm, I agree, but at that point can't you just lash the tiller in place with a constrictor knot?
I guess the various tiller add ons do offer some convenience in that situation.
tager is offline
Help with installing a tiller pilot n0w0rries Gear & Maintenance 5 09-30-2009 03:21 AM
Killer Tiller masslobsterguy General Discussion (sailing related) 7 04-09-2002 10:52 AM
