Topping lift? - Page 2 - SailNet Community
post #11 of 14 Old 11-17-2009
topping lifts are usualy adjustable, either same as a halyard or from the bottom via a line inside the boom . I do not remove only slacken as it is needed to hold the weight of the boom during reefing and I dont fancy trying to reattach to the end off boom with the boat bouncing about all over the place which it almost certainly would be when a reef is needed.K
mintcakekeith is offline
post #12 of 14 Old 11-17-2009
CaptainForce's Avatar
I recently replaced my topping lift adjusters by drilling out a new "Duncan" Yo-Yo.
In the lift position the bitter end nestles in a loop:
When released the main or mizzen takes the load:
One Yo-Yo will refit a ketch! 'take care and joy, Aythya crew
CaptainForce is offline
post #13 of 14 Old 11-17-2009
If it doesnt chafe, leave it even if you get a rigid vang. You never know when an extra line from the masthead might come in handy.
sck5 is offline
post #14 of 14 Old 11-20-2009
I'd second leaving the topping lift in. There are at least two good reasons. First, you can often use it as a spare halyard or to hoist someone aloft if the halyard gets lost up the mast... second, it can be used to hold up the end of the boom and allow you to use the boom as a crane to help bring a MOB back aboard a boat with high freeboard—which you can not do with a rigid vang.
sailingdog is offline
Topping Lift sehopkins Learning to Sail 16 05-04-2015 06:56 AM
Rigid Vang vs Topping Lift jarcher General Discussion (sailing related) 15 10-19-2009 10:28 PM
Topping lift PBzeer Seamanship & Navigation 11 02-19-2004 07:39 PM
Keel Lift NJW3 Seamanship & Navigation 6 09-22-2003 06:59 PM
hard vang means no topping lift? jbarros Gear & Maintenance 14 07-11-2003 08:43 PM
