Printer ? - Page 2 - SailNet Community
Blogs
  #11 (permalink)
Old 11-22-2009
Allanbc's Avatar
Allanbc is on a distinguished road
I have an older CanoScan and I really like it. When I do research at the library, I take it with me and scan stuff rather than copy it. It is faster and cheaper than using a copier at the library. When I get home, I can print out anything I want.
"When in command, command." -- Admiral Nimitz
Difference between a power boater and a sailor out on the water: A power boater is going some place special, a sailor is already there.
s/v Zotz 1981 Pearson 365 Ketch Hull #375
  #12 (permalink)
Old 11-22-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
That is a really good idea, I never thought of it.
What are you pretending not to know ?
  #13 (permalink)
Old 11-23-2009
A lot of the lower end scanners are USB-powered... and work fairly well for the limited needs you might have on a boat
  #14 (permalink)
Old 11-23-2009
n0w0rries's Avatar
n0w0rries is on a distinguished road
You could also try using a digital camera... just take a pic of the doc, crop it on your notebook and then print it.
I hate inkjets, because the ink dries out whether you use it or not. If you seal it that probably helps. Too bad a laser printer would draw too much power onboard.
  #15 (permalink)
Old 11-23-2009
I thought about this, and I don't think the power requirements are the real problem for a laser printer, it is the size of most laser printers that would be the problem. Yes, laser printers use a lot of power just sitting there, but why does it have to sit there drawing power all the time, how often do we print on the boat ? Just reach over, turn the printer on when you need it, then turn it off when you are done.
Working from my office...on a sailboat? Yeah!! (I want-to and need advice)... Jonnie101 Cruising & Liveaboard Forum 22 09-30-2011 02:48 PM
Frequently Asked Computer Questions Jim Sexton Seamanship Articles 0 10-14-1999 09:00 PM
Frequently Asked Computer Questions Jim Sexton Gear and Maintenance Articles 0 10-14-1999 09:00 PM
Frequently Asked Computer Questions Jim Sexton Cruising Articles 0 10-14-1999 09:00 PM
Printers for Onboard Use Jim Sexton Gear and Maintenance Articles 0 10-07-1999 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
