Printer ? - SailNet Community
Blogs
Old 11-21-2009
wind_magic has a spectacular aura about wind_magic has a spectacular aura about wind_magic has a spectacular aura about
Printer ?
I'm curious, how many of you have computer printers on board ? Where do you store the paper on your boat ?
What are you pretending not to know ?
Old 11-22-2009
Paul Cossman
paulcossman is on a distinguished road
I'm getting ready to cruise again, after about five years of landlocked working. My big question is what type of printer is the best to use? My old inkjet is 15 years old and ready to retire. What survives the humid tropical environment best for an onboard printer (on board a 42 footer where space is at a premium)?
BTW, I always just stored a ream of basic white paper in a ordinary locker. No problem.
Old 11-22-2009
lshick is on a distinguished road
Send a message via Skype™ to lshick
We have a little i70 Canon inkjet color printer (about the size of a large book) that we keep in a freezer container (Rubbermaid-style) under the nav station. It has served well for 5 years and shows no signs of deterioration. There are smaller printers now if you're willing to do without automatic paper feed and color and such. The thing to remember is that the inks are water-soluble, so be careful with your output.
I will echo Paul's remarks on storage of paper.
Larry Shick
V42-148 "Moira"
Old 11-22-2009
I'd second the i70, which is the replacement for the old BJC80. THey're very compact and work quite well. Be aware that you can get inks that aren't water soluble once dry.
Old 11-22-2009
bobmcgov's Avatar
baDumbumbum
bobmcgov will become famous soon enough
For cruising, it seems like it would be really handy to have a printer that could copy & scan, too. Apparently many ports want Xeroxes of your documents. Not always a Kinko's handy! But the multi-function printers are seem so bulky (even tho there is almost nothing inside one.) Many docs you could pre-scan and have on your computer for printout as needed, but wouldn't a passport scan need to show the latest Zarpe stamps?
Buccaneer18, Grainnia
SJ21, Diarmuid
Old 11-22-2009
For scanning I went with a simple flat bed scanner, thin, but full size flat bed. It stores like a book and it is not hooked up to the computer unless it is needed, how often do you really scan anything anyway ? On a boat, not very often.
Edit - one unusual thing about the scanner is that it works off of LED's and only has a USB cable, powered completely by the USB port. I found that surprising. It seems to scan okay.
Old 11-22-2009
Paul Cossman
flat bed scanner
Appreciate all the info from everyone. Thanks.
Wind Magic, can you give us the brand and model name of your scanner?
Old 11-22-2009
CanoScan LiDE 200 by Canon, got it at Staples for like 100$us.
Link
I like it because it doesn't need A/C power and because it is thin, about 1 1/2 inches thick I would guess. Gets good reviews on Staples site.
Old 11-22-2009
hellosailor's Avatar
I've got an older Canoscan LIDE scanner. There's no magic to them, and they are outright dog slow in comparison to most scanners that require more than USB power. But, that's the compromise--it is a low-power motor that only needs the power a USB port can supply. For light use, it works very nicely.
I think the latest models all have similar buttons and software, once installed you can press one of three buttons on the scanner and "scan to email" "scan to file" "make a copy" directly with the one push.
Old 11-22-2009
This CanoScan I have is pretty new and it does have those same buttons, actually it has four buttons, "Copy", "Scan", "E-mail", and "PDF", the last one scans into a PDF document. I used to use an all-in-one and I can't say it was any faster, I wouldn't say the CanoScan is excessively slow, but then I wasn't really paying that much attention so maybe it is.
Working from my office...on a sailboat? Yeah!! (I want-to and need advice)... Jonnie101 Cruising & Liveaboard Forum 22 09-30-2011 02:48 PM
Frequently Asked Computer Questions Jim Sexton Seamanship Articles 0 10-14-1999 09:00 PM
Frequently Asked Computer Questions Jim Sexton Gear and Maintenance Articles 0 10-14-1999 09:00 PM
Frequently Asked Computer Questions Jim Sexton Cruising Articles 0 10-14-1999 09:00 PM
Printers for Onboard Use Jim Sexton Gear and Maintenance Articles 0 10-07-1999 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
