11-23-2009
Don Radcliffe
The normal genoa sheet knot is a bowline. There are two sides to the knot, and one tends to catch on things a bit more than others. Tie it both ways to see which works better.
If you continue to have a problem, another solution is to take one long continous line, fold it in the middle, push the folded part through the sail grommet, and then pull both ends through the loop you have created. The knot will tighten up and not slip, but if you want to make sure, take a needle and whipping twine and make a few passes through the knot.
