11-28-2009
There is no specific formula for what size engine you need. You did answer the biggest question which is what role the engine is expected to play. Since you want to be able to push into strong winds, you need some real power and you need the ability to put that power to use. If you plan on pushing into windy conditions, you probably will appreciate having all 8 horsepower. I have spent some time on a Quickstep with a 4hp and it was only good when there was no wind, you couldn't push into 25 knots.
Is the boat only squatting under power? If so, it is likely to be in your engine setup, not weight. How is the engine trim? Are you trying to push your boat past hull speed and causing squat?
Something that is always under appreciated is putting the power into the water. You want your prop as low as possible, not too close to the stern(it will clear the surface in large waves), and as large in diameter as possible. Since your boat has an outboard well, the placement is probably as good as you will get with an outboard. As long as you have a good prop, you probably have a pretty ideal system performance wise although maybe not weight wise.
Do you have a friend with a 6hp that you could borrow and try pushing into a headwind with?
