Old 12-04-2009
dwightgry is on a distinguished road
GRIB files from SSB receiver
Last year I met a guy who received grib weather files on his sailboat using a Grundig 800 SSB receiver. He had no transmit capability, just receive only, connecting the output of the Grundig to the microphone input on his laptop. Does anyone know what software is used for this application?
I'm not looking for mass approval. Is everybody ok with that?
Old 12-04-2009
fud fud is offline
fud is on a distinguished road
Not sure if this is the same software and I've never used this, but it looks like it can be used for what you described. Mscan Meteo Let us know if you try it.
-- Dave
s/v Glass Half Full
1997 Beneteau Oceanis 281
Old 12-04-2009
St Anna's Avatar
St Anna is on a distinguished road
Possibly JV Comm. I use an ICOM but no Tx.
Old 12-04-2009
Thanks for the replies; spent a lot of time searching the net and realize I probably mean weatherfax via ssb, and have found so much info that it's hard to comprehend in one sitting. Actually, wikipedia has some good info, and links, under weatherfax or radiofax. I will be figuring it out for my needs (Bahamas for now) and trying to decipher the info.
Old 12-08-2009
RadioTeck is on a distinguished road
Yes, your right, "weather fax" If you have a radio that can pick up the weather fax frequencies, then you can purchase the software and "soundcard type receiving modem" for your laptop that can take the audio output from the radio (ear phone jack). Give Ham Radio Outlet stores a call, they can help you with what you need.
However if your budget allows, the best is a real SSB transciever and a Pactor type modem then you can request and receive grib files and much more, plus send and receive E-Mail via sailmail or winlink. I know that the expense will be around $4,000 new. Good Luck, Carl
Old 12-09-2009
xsboats's Avatar
xsboats is on a distinguished road
Check out Xaxero SkyEye Weather Fax, Satellite Weather and offshore communications . I've run Weatherfax 2000 onboard for years .
NMEA2000 GPS Receiver question MtHopeBay Gear & Maintenance 7 10-08-2009 10:40 PM
Easy AIS Receiver, Experiences ? wind_magic Gear & Maintenance 1 01-06-2007 08:31 PM
Updating the Navigator's Toolbox Dan Neri Gear and Maintenance Articles 0 07-15-2001 08:00 PM
