Old 12-07-2009
Maverick1958's Avatar
Bristol 29.9
Maverick1958 is on a distinguished road
Send a message via Yahoo to Maverick1958
Window replacement
I need to replace the windows in my Helsen 22. I want some suggestions on material. Should I use plexiglass, lexan, or tempered glass. Additionally should it be clear or tinted. Keep in mind this in a trailer sailor.
Maverick
Old 12-07-2009
tager's Avatar
tager is on a distinguished road
I would use clear plexi. It will be the least expensive. Glass ages nicely, and lexan is very strong, but in your situation, clear acrylic would be easy to work with and cheap.
Deck core replacement from inside the cabin. zz4gta Gear & Maintenance 5 11-04-2009 09:43 AM
Re-install the marine air or keep the window shaker? mikethecapt Cruising & Liveaboard Forum 4 10-23-2009 04:48 PM
Motor mount replacement? bread316 Gear & Maintenance 4 11-07-2006 12:17 AM
jib view window ddilman Gear & Maintenance 2 07-25-2005 10:02 AM
1975 Cal 34 Cabin Window Replacement yellowspear Gear & Maintenance 2 01-06-2005 06:11 PM
