Planned interior upgrades for Oh Joy - Page 2 - SailNet Community
post #11 of 26 Old 12-10-2009 Thread Starter
On the hard
CharlieCobra's Avatar
Charlie,
I was about to echo Fast's caution re the pullman. The Womboat's forward berth is about the same proportions as yours. I would have liked to rebuild it to a pullman but when I laid it out in situ there was no way it was going to work unless we raised the sleeping platform by around 12" which so reduced the headroom as to make it impractical.
That said I agree wholeheartedly with wanting to get away from a v-berth. I am finding that as the old joints start to seize up that doing the v-berth shuffle is becoming somewhat difficult.
cheers mate
Andrew
My preliminary measurements show it will work if using an extension design. That way we still have a bit of access to Starboard of the berth when it's in. The settee may be a slightly lower height then normal to allow the berth to slide over it when opened but I can adjust the vanity height to compensate. It's still in the design phase so it may or may not happen. We can both live with the V-berth the way it is if necessary. I just thought to make it nicer for Fredia, a little more feminine.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #12 of 26 Old 12-10-2009
Moderator
JohnRPollard's Avatar
Charlie,
Good stuff. I like your ideas (although I share the pullman concerns above -- hope you can sort that out. It looks like you might have some headroom and hull flare to work with.)
I especially like the idea of loosing the outboard pilot berth -- they'll make great locker/shelf space.
On the shower, if you don't have room to install a catch pan in the head, you could add a simple drain to a shower sump down in the forward bilge area. It would have a small dedicated bilge pump/float switch that would automatically discharge the grey water overboard.
JohnRPollard is offline
post #13 of 26 Old 12-10-2009 Thread Starter
On the hard
Originally Posted by midnightsailor View Post
Having totally rebuilt several wooden boats including a 1926 Crosby Catboat and more in line with yours, a 1954 S&S 42 Yawl, I understand all the work that is going into your boat. I have been following it closely from the beginning and really admire what you have done so far with her. One thought while your re-doing the interior might be thinking about allowing a place for somthing like an old Luke soapstone fireplace or even a newer type heater /fireplace. Both for warmth and the unbeatablle amabiance afire makes. BTW, I really like the pullman idea. Nice going Rick
I've been looking at heaters and really haven't decided on one yet. I do like the newer Newport Propane units though. They fit in a small space nicely and have a bit of fireplace feel to them. Thanks.
Bellingham, WA.
post #14 of 26 Old 12-10-2009 Thread Starter
On the hard
Originally Posted by JohnRPollard View Post
Charlie,
Thanks for the shower ideas John. I'm still kicking it around. Me? Hell, I'd just shower out in the cockpit but the missus ain't into that...
Bellingham, WA.
post #15 of 26 Old 12-10-2009
tdw
Super Fuzzy Moderator
tdw's Avatar
Lurve dem Newports. Want to move to a colder climate just so I can have one....
Had thought to have one anyway but when you live in a climate where even in mid winter a simple oil lamp (courtesy of the Stillmeister) quite adequately takes the chill away its hard to justify.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #16 of 26 Old 12-11-2009
48' wood S&S yawl
cormeum's Avatar
We have a Luke soapstone. Works great. I'd recommend it. Put a granite slab underneath though.
cormeum is offline
post #17 of 26 Old 12-11-2009
midnightsailor's Avatar
Luke Fireplace
Cormeum,
I love those old S&S designs in wood. Is your boat Luke Built? If I could find an old Luke soapstone fireplace, I would rebuild my boats interior just to find a place to instal it. I think they are really lovely to look at , and a great way to add some extra heat in those cold winter days.
midnightsailor is offline
post #18 of 26 Old 12-11-2009
blt2ski's Avatar
Is it snowing up that way yet Charlie? BIG cloud line looking north when I was driving north on the viaduct a bit ago back home to edmonds.
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #19 of 26 Old 12-11-2009 Thread Starter
On the hard
We had some light flurries at dawn but nothing since. If it snows, we'll get some...
Bellingham, WA.
post #20 of 26 Old 12-11-2009
48' wood S&S yawl
cormeum's Avatar
Cormeum,
Thanks midnight, ours was built at Derecktor's. We do have a Luke stove and the fireplace.The fireplace was original equipment and we replaced the alcohol Luke stove with one in LPG.
They are still making the same ones:
Paul E. Luke, Inc.
cormeum is offline
