12-18-2009
Swageless
Check out Unicorn Stainless. They have advertised here. No I don't work for them. I am upgrading my Oday 22, and since the nearest rigger is 2 hours away, this is most cost effective. The fittings are nice. Simple to assemble. And I feel more confident in them than swaged terminals. I can also repair and reuse with a new cone. The cost of the terminals is around the cost of a swage tool from WM. (less turnbuckles)
Also, silver solder is higher temp, higher tensile than 60/40 tin/lead solder, but I still would NOT use it. The higher temp, close to bronze welding, would bring up the carbon in the wire/fitting and promote corrosion.
