Old 12-20-2009
interlude44 is on a distinguished road
G5 5/16 HT Anchor Chain
My anchor chain is stamped G5, which I presume to be stronger than G40, but perhaps not. It was supplied with my boat by its European manufacturer.
I now need a new windlass to replace my Simpson Lawrence Sprint 1500, and Lewmar have said that their various 5/16 Gypsy offerings may not work.
Any advice would be helpful? Thanks.
Old 12-20-2009
imagine2frolic's Avatar
imagine2frolic is on a distinguished road
If the dealer of the windlass is close. Cut off a piece of the chain, and take it there. Any dealer should be able to tell you if it will fit if you know exactly what you have.....i2f
20 MPH ain't fast unless, you do it in a 1000sq 3/2 house on 10foot waves
BORROWED, No single one of us is as smart as all of us!
Old 12-20-2009
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Test fit
Yes, for Heaven's sake do a test fit least you end up doing like a dumb friend of mine did and buy chain (or windlass) three times before it fit.
It was me.
Hey, can one of you guys pass me a crab?
Old 12-21-2009
Craig Smith's Avatar
Anchorsmith
Craig Smith is on a distinguished road
Is it stainless? G5 is an unusual grade for galvanized. G5 is the common high tensile stainless grade and either way yes is stronger than G4 or American "high test". Are you sure it's 5/16" and not metric? Very close to 8 mm but not exactly 8 mm might work okay with any given 5/16 gypsy, or might not. You will need to know the exact pitch measurements and compare with the windlass gypsy options. Talk to the manufacturer not local retailers, if for example you need to get hold of a metric gypsy.
Craig Smith
Sailnet Disclosure: Craig is the son of the designer of Rocna and has a financial interest in its success.
Old 12-21-2009
Thanks for the advice. No, I am not sure that it is 5/16. All I am going on is the description of the anchor chain when I bought the boat, which stipulated it as - 75M/246 ft HT anchor chain, 5/16". A metric gypsy may be the answer. The current Simpson Lawrence Gypsy is stamped and numbered 172.
5/16 high-test gypsy for SL555? wsitch Gear & Maintenance 5 08-08-2006 04:40 PM
