12-22-2009
Old Fart
Marine Plywood
Originally Posted by johnshasteen
You might try making two hatch boards - the lower board from acrylic and the upper board from marine plywood (varnich the plywood). That will give you a strong point to attach your companionway lock and some visability and light from inside the cabin when the boards are in.
Good idea but keep the acrylic to a minimum as it just isn't as strong as ply. Also don't let the lumberyard sell you just any plywood as "marine". Yes, all plywood is made with water proof glue but the marine grade is made up of more and thinner plys.
My companionway hatch is a double door hinged on both sides with louvers on both sides and is backed up with a three piece solid set of boards that slip in behind the hinged doors for strength in case of real bad weather. I've never used the boards but it's nice to have them.
Hey, can one of you guys pass me a crab?
