12-22-2009
According to "Seaworthy" (the Robert Adriance book that reviews BoatUS insurance claims) . . . "Whenever a boat is stored in the water over the winter, all through-hulls, with the exception of the ones for cockpit drains, must be closed, or the boat could be on the bottom next spring. All through-hulls, especially the ones for cockpit drains, should be double-clamped with stainless steel hose clamps at each end. While not required by ABYC standards, double-clamping is nonetheless critical for cockpit drains in colder climates (and it's a good idea on all other through-hulls, regardless of climate.) The reason being that as water freezes, it expands and consequently will lift a poorly secured hose off a fitting. The hose itself is also important. Lightweight hose and PVC tubing can rupture or crack. Use only a heavily reinforced hose, especially at cockpit drains."
I've also heard of the weight of snow pushing a boat down far enough in the water to push a bilge pump thru-hull below the waterline, and if there is no vented loop installed, a siphon can set up.
