Stern tying
17K views 18 replies 12 participants last post by  SVPrairieRose
#1 · (Edited)
Here in BC we are blessed with plenty of sheltered anchorages, and a good number of them are marine parks and as such are very popular destinations that fill up quickly. Few of these bays are truly shallow, making free swinging with adequate scope difficult if not impossible ( 7:1 'textbook' scope can rarely be practiced here)
As a result the only way to accomodate the large number of boats is for the majority to stern tie ashore, essentially eliminating swinging and opening up a lot more space in any given bay. In the Gulf Islands as result of glaciation many of the bays are long and skinny adding to the difficulty of using adequate scope to swing free.
Here are a few things we try to pay attention to when we anchor in this fashion:
In the diagram above, I've deliberately shown a couple of things that are not going to work.
It's crucial, of course, to factor in the expected tide changes for the duration of your intended stay. Grounding is a lousy way to wake up in the early hours.
In the picture, the clearance under the boat's sounder is probably enough to appear that you'd "stay afloat" at the indicated low tide, but as you can see the rudder will in fact be on the sloping bottom long before that. Knowing your bay and how steep the drop off is is helpful. The newer flashlight-sized battery powered depth finders are really nice to have to check the depth under the rudder when you're done setting up. Failing that a lead line (or a wrench on a string) can get the job done too.
Also, as the tide drops you need to be aware that your boat will slide aft both due to the increased effective scope on your rode, and the radius of the line ashore that will pull the boat closer. Remember in BC tidal changes of up to 15 feet are monthly occurences, with 8 - 10 feet normal daily.
More scope, and long lines ashore minimize this particular tendency to shift position but they also allow more lateral movement as the tide drops and/or a cross breeze develops, risking drifting into a nearby neighbour. In small coves in may be necessary to set two lines ashore to 'triangulate' and lock in your position relative to other boats (or rocks/shoals)
The orange arrow shows that the stern line is riding on the shore. If this is rocky, chafe can be a problem and it's a good idea to scrounge a driftwood log (or perhaps a spare fender) to lay under the line to avoid that
Shore tie lines should be brightly coloured, floating line. We carry 350 or so feet, many carry up to 600. These lengths allow the line to be led around the tie off point and back to the boat to allow retrieval without having to go ashore. However, retrieval can tend to 'saw' through the bark layer of a tree as the line is dragged around, so if you're going to use a tree, tie a sacrificial loop around the trunk and run your shore line through that. We generally leave the loop in the tree afterwards for the next guy. Try to avoid tying to the fragile Arbutus (Madrona in the US) trees. It's also a good idea to attach a fender to the line midway to shore to enhance visiblity for those dinghying around behind boats.
Most marine parks here have installed rings into the rock around the bay, usually flagged with surveyor's tape or a paint splash so they can be seen from the boat. These should be your first choice. In some areas where the banks/cliffs are tall there are chains and hoops hung from these rings for easier access from the water.
If you intend to stern tie, you should do some pre-anchoring preparations. Have your stern line flaked out so it will deploy cleanly. Many use reels nowadays, or stuff bags which can help avoid tangles, but we find reels very slow for retrieval. Have a tender or kayak ready to go ashore to run the line in minimal time... sometimes you're under the gun if the boat won't stay still while you go. Depending on the boat and the conditions, when pulling gently against your rode in reverse the prop walk may help hold you in place (or not....)
As with anchoring in general, work out some hand signals so that the rest of the bay doesn't hear you yelling at each other.. if the boat is happy to sit there, shutting the engine off helps communication too.
This technique will also make it possible to enjoy some real neat one-boat nooks and crannies once you're onto ways to "immobilize" the boat while in the hook.
Here the anchor's in about 80 feet of water, (no windlass between us :eek: ) and we're tucked into a tiny nook for overnight protection.
Now.. there is a major precaution here.. if your anchor drags, the first place you're going is to the beach (since you're literally tied to it!). Its crucial that you set your anchor well and avoid heavy cross winds and cross currents which can put inordinate loads on your anchor and rode. We were once in that situation, the water seemed to be literally boiling out from under the keel, current dead across the beam - and the anchor let go. We immediately starting arcing towards shore. Luckily we were aboard, and we cast off the stern line, the boat swung round and the anchor reset. We were lucky too that there were no other boats down-current... and we nearly got caught for not paying attention and thinking things through.
In the right time and place, though, and here in our summer season it's the only way to accomodate the numbers of boats in popular spots.
See less See more
6
#2 ·
Faster, you ought to put this and the raft-up post in the "Articles" section. I browse through there quite a bit looking for info - and most of it's pretty old. With your writing, photos and drawings, this is great info that should be preserved.
#5 ·
Faster
That is a great article. Would you mind if I used your diagram in my PowerPoint presentations that I use when teaching? Let me know how to credit it.
You cautionary note about dragging is crucial. I have noticed a number of boats going stern-to without setting their anchor. Scary.
Jack
#7 ·
Ron,
Great info. I can't wait to cruise there someday.
As I read your diagrams and descriptions, my instinct for solving the issue of the falling tide and potential grounding of the rudder, would be to set the primary anchor off the stern and tie-off to shore from the bow. Is there an argument against this?
#8 ·
Thanks John... as to your suggestion, that's an obvious solution and one that's practiced extensively in Scandinavia where they often have open pulpits and can get directly ashore off the bow.
Oddly, I've never seen a boat 'nosed in' around here, nor have we done it ourselves. I suppose mostly because generally there's enough depth right up to shore (or within reasonable distance) that it's not required.
And besides, it wouldn't be 'stern tying' then would it??:D :rolleyes: :D :rolleyes:
#9 ·
In Turkey, we used to do a Med moor bow-in. That gave us privacy in the cockpit.
#10 ·
Tips that have worked for me
Faster,
I have stern tied many times, particularly in Desolation Sound. My wife and I use a "2 line" system to make deploying the stern tie line easier. I have often seen other boaters struggling trying to row back to the mothership towing the stern line after it is wrapped around a tree etc. ashore. We use a second much smaller line for "pulling the main line" back to the boat. I row ashore towing 2 lines. When ashore, I pass the stern tie around the "anchor" and then clip the second smaller line to the stern tie. (At this point) Back aboard, my wife pulls the second line in, bringing the stern tie with it. No hassle trying to row back pulling a line that has a lot of resistance in it. I use a thin line on a "garden electrical cord" reel to make deploying and storing the smaller line easy.
Another point that works fairly well, when using a tree as an anchor for the stern tie, I use a bridle make out of 5/8" line. This bridle is about 7-8 feet long and has a small thimble spliced in one end and a larger ring (about 5" diameter) attached to the splice at the other end. Pass the stern tie through the small thimble first and through the ring last (bridle goes around the tree). The bridle does not move much, thus minimizing the chafe on the tree as the stern tie moves through the spindle and the ring. When retrieving, tie a bowline in the end of the stern tie line. It will pass through the ring, but will "grab" the smaller spindle and bring the bridle back with it to the boat.
Hope I explained this well enough that you can understand what I mean,
Tom:)
#14 ·
Tom:)
Good post Firehoser. I drew this up but I had to go away for a few days and in the mean time I saw your post and this real good description. So here is a drawing similar to your description.
#11 · (Edited)
Sounds like a good system, hoser;) (... sorry.. Tom)!
Your second point is, I suppose, a retrievable version of the loop around the tree that I described above.
Thanks for the input!:)
#13 ·
Choice of anchors is pretty much across the board... we used a Danforth for years, now this boat has a CQR that has yet to let us down, though setting in 'marbles' is a bit iffy.
But looking around the marinas here you'll see the complete cross section. Since our nights are generally very settled in summer, there's rarely serious pressure on one's ground tackle.
By the way, many (but not all) of these 'rocky' bays actually have mud or shale bottoms.
#15 ·
On the Small work boats (under 165 ft) here in the Gulf of Mexico, We stern up by pressing our sterns hard to the quay wall and put out two lines.
Of course it helps to have a square stern fendered with old Airplane tires. :D
#18 ·
As Usual, Faster has it right
Thanks for the great diagram Seeyalater, it adds to the description. Faster is correct about the "bridle" potentially fouling in the cracks and crevices along some beaches. However, with a bit of practice (and patience), the line can be somewhat "guided" back by pulling sharply just prior to it reaching any noticeable problem areas. That and a bit of luck have resulted in my line only requiring a trip ashore on 2 occasions out of about 20 so far. Those 2 times were earlier in my learning curve....... but I am not saying that this can be completely avoided, only that the number of problems can be reduced. Faster, 2 areas of concern with leaving line behind, 1) the potential for it to become a piece of "polution" if it ends up in the water, and 2) the "dependability" issue that you describe. If it is your own line (bridle), you should be able to have more faith in it by knowing how it has been used.
Anyway, both workable solutions, and both will reduce damage to any living trees we use as stern tie attachment points.
Great thread,
Tom:D
#19 ·
Lets not forget that trees pass water and nutrients in the bark and outer layers of wood. If the tree were to grow in girth over time with a bridle left around it, that could "suffocate" the tree and kill it. I would suggest that if you are not going back to the same place again, don't leave anything behind, Ill bring my own bridle, thanks. Great article, thank you.
