Old 01-01-2010
Rippin is on a distinguished road
Yanmar 38 HP Installation Advice
Good Morning, We have bought a new ( 10 years old but still in crate), 38 hp Yanmar 3jh 2 c e. With our new motor came a basic owners guide but our shipwright needs an installation manual. It will have measurements etc for positioning mounts and the like.
Is anyone able to help or provide advice. I have rang the local Yanmar agent but they are not open until Mon 4th Jan.
Thanks & Regards
Lucky
Old 01-01-2010
yachtwork is on a distinguished road
Yanmar instalation
Best install info I know of is here-
How to change a yacht engine
I wrote it for guys in your situation.
Also, if the engine has been sitting for ten years in the crate then be sure to use the starter to turn the engine over while holding the stop till you have built oil presure. The engine will be dry in side and this will help.
Good luck
Scott
Disclosure: Yachtwork is a marine vendor
Old 01-01-2010
xsboats's Avatar
xsboats is on a distinguished road
I'm not sure I would have someone who needs an installation manual for a marine diesel install one in my boat. Or to better put it, someone capable of properly installing an engine would know where to locate any information they were in need of to do so.
Old 01-01-2010
Red
redhead78 is on a distinguished road
Rippen, where are you located, I am in NJ doing a repower with a 35HP beta Marine engine.......Red
Red, 77 Jeanneau Gin Fizz 38
Old 01-02-2010
Fitting New yanmar 38hp
Hi Folks, Thanks for your very prompt & helpful advice, it is useful already.
We are located in Cairns, Queensland, Australia.
Our Shipwright has been doing this task for 40 years or so. The new motor has only the standard Owner type manual, in which it advises "should installation information be required please see your Yanmar Dealer for an "Installation Manual". We have complete confidence in our ship right; the 42 hp 4 -cylinder Mercedes that we took out, is about 130 % the size of the three cylinder Yanmar 38 hp. The shipwright is seeking accurate engineering drawings with measurements to assist placement of mounts & alignment etc. There is a lot of information available on the net but I haven't found this exact model yet.
Thanks & Regards
Phil
Old 01-02-2010
Red
Did you try yanmar.com....
Old 01-02-2010
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Good Stuff!!
Good luck
Scott
Scott,
Thank you for the detailed writeup! I agree w/ you that replace is better than rebuild.
Two nits - there were a couple of pictures that didn't load for me (maybe because I'm in the US, maybe b/c I use Chrome as my browser). Also a lot of the pix had captions, but some (some important ones!) did not.
RE: Yanmar Installation Manual - Yanmar - Sailboat engines
RE: initial cranking -Because this engine has been sitting for 10 years, I would add a teaspoon of 2 stroke oil to each cylinder through the injector port. With the injectors out, raw water and fuel shut off, I would turn it over a couple of times to coat the cylinders with oil. Then I would replace the injectors, and proceed with the installation.
ASA 101/103/104/105 Certified - Also certified in Recreational Marine Electrical Systems
Old 01-02-2010
I'll look at it again today and try to clean up the installation page later today. Someone mentioned yanmar.com, you can also try yanmarhelp.com and for manuals try burningzone, you'll have to do a search as I don't have the full site, but they have free downloads. I don't recall the mount to crank specs being in the installation manual. That has things more like pto mount specs, and how to install, but if your looking for the measurements for building rails I think you will find them in the specification sheets. The installation manual is for all engines and more general. At least for the version I have seen anyway.
Okay, I'll look at cleaning up the install page later today.
Thanks
Scott
Need advice on engines - Westerbeke 30B or Yanmar 3YM30? Terry60 Diesel Engine Forum 15 01-31-2010 01:51 AM
Need Ham Radio Installation Advice VenturaBoatDoctor Gear & Maintenance 10 10-27-2009 10:54 PM
Yanmar installation manual prussell Gear & Maintenance 9 12-14-2007 04:53 PM
