01-04-2010
Originally Posted by SiXeVeN
I can't use the midship anchor idea (would work great) because it would put a line into the canal center. It would be a potential nav haz for other boaters.
If I understand the fenderboard concept correctly. You place the cushioned ends of the 2x4 against the boat then the board becomes a temp rubrail... I guess you could also then use fenders between the board and the sea wall. OR, I guess you can nail a long board between the pilings and then conventional fenders won't roll off...
The only issue is this will be a 24-7 mooring so any prolonged contact to a fixed rubber/foam cushion will ultimately wear down the paint. But it sounds like the first option may prevent that., if I could keep the fender board from moving Hmmmm. That just might work.
Anyone see a negative to a using a semi rigid rod to hold the boat away from the wall and then using triangulated dock lines to keep the boat centered???
The idea behind a fenderboard is to use fenders on your hull as normal and then have the fenderboard bear against the piling. The reason that you do this is so that the fender will not pop out of the way of the piling. Generally, there is one fenderboard forward and one aft. You first hang your 2-3 fenders vertically. Then you take your fenderboard with a line through each end and hang it down so that it is halfway down your fenders. Fenderboards need to be at least a few feet long to be effective and get to over 15' long on larger vessels. There are no fenders between the board and the pilings, it is wood on wood contact.
In the case of a concrete wall, a fenderboard is not useful. Fenders will tend to chafe against something like this. Probably your best bet is to use large fenders. Also, there is a decent chance that there will be camels which must be dealt with differently to prevent your bottom paint from being taken off.
The other thing to do is look at the other boats around you. Someone has probably figured out a good solution for your situation.
