01-25-2010
I wouldn't use a CQR, even two 60 lb ones.. you're much better off using a mushroom anchor of significant weight, which is specifically designed for the purpose. Better yet, a helical screw mooring would be even more secure.
BTW, how heavy a boat do you have. There is a fairly wide range of displacements for 30' boats.
If you do have to use standard anchors, I would suggest three large danforths, rather than CQRs. Danforths have great holding power, more so for the weight than do CQRs and if you have three of them in a y-shaped layout at 120˚ from each other, the load will generally be split between two of them and none of them will be subjected to much in the way of twisting loads that can cause them to unseat.
