  #1
Old 01-29-2010
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
Question Antifouling a center board ???
I have a 44 footer with a big centre board. Draws 5 foot with the board up and about 9 with it down.
Does anyone have experience with cleaning and antifouling something like this.
Do you get it propped up really high? Work in a pit? Get them to give you a few minutes in the slings before it is launched, drop the keel and slop on a coat and hope it dries in time.
  #2
Old 01-29-2010
It might be worth dropping the board completely and checking out the pivot pin while you have the boat out of the water.
Otherwise, having the boat in the slings is probably the best approach... you might try seeing if they can leave the boat in the slings overnight... hauling in the afternoon and then you have the afternoon and evening to sand and paint the centerboard. Don't forget to sand and paint inside the centerboard trunk.
  #3
Old 01-29-2010
josrulz's Avatar
Unpaid Intern
josrulz is on a distinguished road
We have a keel/centerboard on our boat, and need to sand the centerboard back down in the spring and put new anti-fouling on it. The yard suggested, as sailingdog did above, that come spring we'll put her in the slings in the afternoon/evening and drop the board. Then we can sand, paint, whatever, and splash the boat in the morning. Our plan is to get whatever paint we want on it in the evening, so it'll dry in plenty of time for launch in the morning. So that's indeed the plan.
I agree with SD on the point of checking out the pivot pin and cable while you're at it.
-J
1984 Sabre 34 Mk I
You may post attachments
You may edit your posts
What can you tell from the numbers? brazilnut Boat Review and Purchase Forum 10 07-01-2009 04:09 PM
center board question dmr_invicta-II Gear & Maintenance 0 07-01-2004 09:40 AM
Center board jams..Help brusail6 General Discussion (sailing related) 4 05-03-2002 05:20 PM
Center board jams..Help brusail6 General Discussion (sailing related) 0 05-02-2002 04:42 AM
Cooking On Board Sue & Larry Cruising Articles 0 06-11-2001 08:00 PM
SEO by vBSEO 3.6.1
