Wheel vs Tiller - Page 3 - SailNet Community
post #21 of 29 Old 02-22-2010
Practically a wheel takes up less cockpit space. With a tiller you lose seating. I like the tiller because I further forward and closer to the dodger. A tiller has better feedback withe the boat. With wheels a cable system have some feedback. Hydraulic wheel systems have no feedback. I think for smaller boats 30 ft or so autopilots are more reliable and less costly than wheel autopilots.
Waltthesalt is offline
post #22 of 29 Old 02-22-2010
I'd point out that with a tiller you may lose cockpit space while underway, but you have a lot more cockpit space when at anchor, since you can tilt the tiller back and out of the way...
sailingdog is offline
post #23 of 29 Old 02-22-2010
bljones's Avatar
SOME can be tilted up, SD. Folkboat tillers and many thru-transom tillers do not have that option.
bljones is offline
post #24 of 29 Old 02-23-2010
blackjenner's Avatar
One major issue in favor of tillers is the simplicity of the system. A tiller is far less maintenance and far less complex. Also, many sailors feel that a tiller steered boat gives the sailor more feedback than a wheel-steered boat. Tillers can be used on even very large boats, given that they are designed for it. One of my favorite large trimarans is tiller steered and comes in at 18 meters long... seen below:
Also, you can setup sheet-to-tiller self-steering fairly simply, which is generally not an option with a wheel.
Good god!
blackjenner is offline
post #25 of 29 Old 02-23-2010
BlackJenner—
What's wrong?? Impressive, ain't it...
post #26 of 29 Old 02-23-2010
BlackJenner—
Nothing was wrong. I was in awe.
post #27 of 29 Old 02-23-2010
bljones's Avatar
Damn SD, do you have a MEWS (Multihull Early Warning System) that alerts you everytime somebody comments on one of those watertrikes?
and no, this does not mean you need to post the youtube video of you faking speed on your trike. It was all done with CGI anyway.
bljones is offline
post #28 of 29 Old 02-23-2010
Yes, I do... but it only works on intelligent life forms...for some reason it doesn't go off when you post. :
post #29 of 29 Old 02-23-2010
tager's Avatar
Tiller. More seaworthy. More feedback. Simpler. Better.
tager is offline
Tiller to wheel conversion costs? 808state Gear & Maintenance 13 06-30-2012 07:11 PM
Tiller vs. Wheel Paisan General Discussion (sailing related) 35 11-03-2010 06:42 AM
