02-09-2010
Not a great idea, since in a storm or with reversing current/wind, you might end up breaking the wire and tripping the anchor prematurely.
It is a lot like the "rock slot" found on the Manson Supreme Anchor's shank.
My question to my friend who thought it was a great idea was: "How does the anchor tell whether you've pulled the rode forward to free the anchor or whether the storm has pulled the rode forward because the wind has shifted?"
My response was, "It doesn't... in one case the anchor comes out...in the other the anchor comes out and you lose your boat." The look on his face was pretty priceless...and he doesn't own the Manson Supreme any more...
Originally Posted by n0w0rries
Whenever I've seen an anchor setup with a trip, the anchor is attached to the rode at the crown, and then the rode is attached a second time to the end of the shank with wire. The idea being if the anchor won't budge, you pull hard enough to break the wire, which means you are pulling the anchor from the crown.
Seems to me if you had 2 lines you'd be untangling them a lot.
