02-14-2010
IMHO, a 20 KG Delta is a bit on the small side for a boat the size of yours. I think you'd be better off with a 20 KG Rocna or 45 lb. Manson Supreme. These will have significantly more holding power and set better than a Delta, and are more appropriate a size for your boat.
You will probably want at least 5/16" G43 HT chain with 5/8" nylon rode at a minimum, though this is probably a bit light for a boat as large as yours. However, the windlass gypsy is the most important determinant of what you can use for an anchor rode, so you should check that first. BTW, this is one of the most common rode specifications for smaller boats...
Originally Posted by Luis58
Dear all,
I ordered my new Oceanis 40 which will be delivered in May  . I decided not to order the Easy Docking Pack and I am trying to choose a good anchor. I am thinking on a 20 kg Delta by Lewmar. The boat comes with a 1000 W Electric windlass. I would like to know from the experts in this site, what diameter of chain and rope I should get. I will have many doubts as my sailing experience is minimum and I would like to get in contact in Oceanis owners that do not mind to give advice.
Kind Regards, Luis
