02-19-2010
Originally Posted by SVAuspicious
My boat is pretty heavy and I've been quite comfortable in what others consider bumpy conditions. My principal interests are depth and dinghy access.
Since you seem pretty well set on the Harbor over the Pond I should add that anchor setting and holding were good. Even though I only spent 1 night I had to re-anchor because the guy in back of me yelled to say I was too close to his anchor..... maybe, maybe not.... but anyway... I pulled up and re-anchored again in 20' of water well away from him in about 15kt winds with no problem. Even though it is a fairly large harbor, on a Saturday night it's surprising how fast it shrinks when looking for a 300' swing circle amongst the lobster pots, access channel running through the center of the harbor, and the other boats. And..... being on a point at the junction of LI Sound, NGBay, and the big bad ocean I wouldn't consider dropping anchor without having that full 360 degree swing available because overnight/next day/ afternoon SWesterly 180 degree wind shifts in NGBay and the area are the Norm not a maybe. As for comfort.... I do usually spoil myself with better protected areas  but at 18,000 lbs. my boat rides it out pretty well..... but like I said .....Uncomfortable
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
