Old 02-22-2010
elkscout's Avatar
elkscout is on a distinguished road
what is up swung bow?
I was reading a thread where it was mentioned that an "up swung bow" was one of two characteristics/criteria for a boat to be considered bluewater capable. Something about reserve buoyancy?
Will someone describe this or give another term for this type of bow design?
I googled it, but came up empty handed.
Old 02-22-2010
nolatom will become famous soon enough
Probably just means the shear strake rises and curves upward towards the stem, giving more freeboard forward to keep the big seas off the deck much as possible. Sometimes called upswept.
then you have your bow types (clipper, spoon, plumb, etc) but that's a different question
Old 02-22-2010
tager's Avatar
tager is on a distinguished road
I don't understand the need for overhangs, you can design a lot of reserve stability into a plumb bow.
Old 02-22-2010
JohnRPollard's Avatar
Moderator
I assume you mean "reserve buoyancy"? Stability is not really part of that equation.
While moderate overhangs and moderately upswept bows do create reserve buoyancy in the bows by virtue of the larger hull volume, more importantly they have an effect on comfort via both the gentler motion they impart and the better ability to deflect spray.
It is very difficult to achieve these benefits with a plum bow, without either making some very distorted hollows in the bow section -- which then has a negative effect on reserve buoyancy -- or creatign a very bluff entry -- which is undesirable as well. Most designers simply go for a moderately fine entry, so comparatively wetter decks and cockpit are a compromise you generally have to live with with a plumb-bowed boat.
Also, from a cruising standpoint, handling ground tackle is complicated by plumb bows. Whereas with an overhang, it is much easier to avoid damaging the bows with anchors and tackle because the bow rakes back and away from ground tackle as it descends from the roller.
Old 02-22-2010
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
Not much. How 'bout you?
And who you calling "swung bow," anyway?
Old 02-22-2010
xsboats's Avatar
xsboats is on a distinguished road
I see bljones made it to happy hour early today!
How to Steer in Waves Carol Cronin Racing Articles 0 06-10-2002 08:00 PM
The Basics of Doing the Bow—Part Two Rich Bowen Racing Articles 0 04-03-2002 07:00 PM
The Basics of Doing the Bow Rich Bowen Racing Articles 0 03-20-2002 07:00 PM
Hull Speed Demystified Steve Colgate Learning to Sail Articles 0 06-10-2000 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
