02-23-2010
Midwest Puddle Pirate
Originally Posted by scottyt
how about running the chain over a drum with a weight on the chain, the larger the weight the more tension. if you need more travel than you have depth, you can do a 2 or 3 to run set up.
or maybe add weight in the middle of the chain, kind of like an anchor sentenal. this would in effect shorten the scope of the chains
Maybe a picture of your first setup would help me see what you're talking about. I thought about the anchor sentinel type setup. I don't think it would give me the range that I need.
I ran the below design by my friend Scott (P.E. PhD). He gave me a couple of good reasons why this would be difficult to pull off. Not the least of which would be the calculation of the length of the rode. Apparently it's not as easy as it seems. He said he has a program that would do the calculations. Maybe he's trying to get it down to an exact length (like a good engineer should), I would just like it to be within a couple of feet. The other problems would be getting an exact location on each anchor. Easy to plan to put them in on a straight line, not so easy to get them placed and set.
This would be the view of the end of the dock section.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. John USYacht 27 "Cora Lee"
