Fractional to Full Rig? - SailNet Community
post #1 of 3 Old 02-12-2003 Thread Starter
I am replacing the mast on my Spirit 23 and thus have the opportunity to change the rig to a full from the current fractional. I am thinking of this so as to have better control over mast shape. Are there any disadvantages to this?
rhbroehl is offline
post #2 of 3 Old 02-12-2003
Moderator
Jeff_H's Avatar
Yes there are lost of disadvantages to this. Your boat was probably designed as a fractional rig and going to a masthead rig would give you leehelm which is dangerous in high winds.
Beyond that with a fractional rig you generally have better control over mastbend, and pumping and lower compression loads than a masthead rig.
Beyond that you will need all new headsails cut to fit this new configuration and the foretriangle may have too high an aspect ratio to really work well.
Jeff_H is online now
post #3 of 3 Old 02-12-2003
paulk's Avatar
By the time you''ve fixed all the problems Jeff H brings up, you will have found out it would have been cheaper to buy a different boat if you wanted a masthead rig. Certainly a lot less hassle.
paulk is offline
Sloop vs. Fractional Sloop vs. Cutter Epiphany Boat Review and Purchase Forum 39 01-31-2016 08:12 PM
Sloop, Cutter or Ketch jsgsail Boat Review and Purchase Forum 17 12-26-2008 03:47 PM
New to Sailing, please Help =) xyris Learning to Sail 19 11-17-2008 09:30 AM
Fractional vs. Masthead Rig max-on Boat Review and Purchase Forum 7 06-14-2004 02:37 PM
diffrent rigs? (schooner, ketch, cutter, sloop) jbarros Boat Review and Purchase Forum 2 07-09-2003 05:10 PM
