03-03-2010
Is the backstay the same diameter as the forestay? If so, you aren't gaining anything.
How would you attach the second backstay? If you plan on using a toggle and a diamond plate attached to the same pin that the backstay is currently attached to, you're not really gaining anything.
The boat was designed with the set up you have now and has evidently performed well. Why fix it if it isn't broken?
The best thing you can do to achieve the peace of mind that we all want to have concerning our rigs is to inspect everything thoroughly and often. Replace things that are suspect or beyond the manufacturer recommended lifespan. With rigging, as you know, that will change with climate.
Try not to overstress or shock-load the gear if possible.
I look at it the same way I do when asked about upgrading wire size. It really won't hurt anything except adding a little weight, but it really won't help either. Unless you redo the entire system from the chain plates to the mast attachment.
You can't just drill a bigger hole, install bigger wire and gain any strength.
Ron Paul 2012
"wikijar"
