03-17-2010
From an exterminator's website.
Palmetto bugs are reddish brown and grow up to two inches in length. It is also known as the American cockroach. It has a pair of large wings on its back that can be used for flying, but wings that are tough enough to act like a shield when the cockroach is on the ground. Palmetto bugs need moisture to survive and only live in warm, tropical climates. It can be found outdoors across the southern United States, but is also a common insect found in commercial facilities with high heat and humidity.
