03-23-2010
Oh, yes -- Cayuga lake -- one of NY's glacial finger lakes. 3 miles wide and 30 miles long - 40 long if you include the mud flats.
Sailing on Cayuga, I shouldn't think you would need so much motor as you would in a bay or sound. If you ever want to sail down to NYC and sail the Long Island and Block Island sounds, you should probably get a 5 HP motor. Otherwise, a 3.5 or 4 HP motor should be fine.
The Dog makes prudent recommendations in general and it is almost always warranted, but in this case I will conditionally disagree. Although SD makes a good point about the weight, the smaller HP 4-stroke motors of today are lighter than they were even 10 years ago and are even close to the weight of '70s 2-strokes. However, I have my own cautions to issue:
Don't get a bigger motor than you need. The bigger they are, the more expensive they are, the heavier they are, and the harder they are to horse around -- even when it is mounted on a movable motor mount that helps you lift it (I have personal experience with this on my sailing club's Cat 25s).
Also, I'm guessing that you recently bought the boat since you are looking for a motor and "it came without one." If you didn't get a survey done before purchase, I'd recommend getting one now to understand fully the boat's condition and to find and prioritize all the things that need to be fixed. It will also ensure your hull (and specifically the transom) is sound and can handle the forces the motor will generate.
Happy sailing!
DaCAP
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
