Old 03-21-2010
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
PortaBotes as Tenders w/Torqeedo
I personally like the PortaBote that my wife bought me for use as a fishing boat... it works quite well as a dinghy as well. One bonus is that it is relatively compact when folded up.
I'm glad to hear SD say that. I bought the 8' PortaBote at a Boat Show two weeks ago, although the factory is a bit behind and I'm still awaiting delivery. It looks like it should fit nicely tied to the lifelines forward.
I have two questions for those who have used a PortaBote:
1) What do you think of PortaBote stability? My wife is scared to death of small boats, being a non-swimmer (I keep her in a PDF at all times) and I'm hoping to reassure her with others' experience.
2) What do you use to power your Portabote and what sort of speed do you get? I'm considering the Torqeedo Travel 801 S. I'm sure it will be fine for tender duty here in the Chesapeake but maybe not for repeated long runs in the Caribbean after I retire again in 8 years or so. For that perhaps I would need to add an external battery.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
Old 03-21-2010
I don't know how the Torqueedo will do, but my 3.5 HP tohatsu was great. As for stability... the flexibility of the hull bottom makes it pretty tough to upset.
Old 03-22-2010
mberoz is on a distinguished road
My wife & I also have an 8 footer and find it very stable. We've used it for 3 seasons now & never have had a close call. We power with a 3.5hp Nissan 2 stoke. Can't tell you our speed, but fast enough. When alone I can plane easily.
Marc
Old 03-23-2010
Thanks for your thoughts! I feel better now about my plans.
T. P. Donnelly
Pasadena, MD
Old 03-23-2010
erps's Avatar
the pointy end is the bow
10 footer with 3 h.p. 2 cycle Johnson will get me and the dog on a plane, but not me and the wife. We do not regret puchasing the portabote although I'm working on modifying the oar locks to facilitate regular oars instead of those cheesy aluminum ones.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 03-23-2010
Rodney Sheaffer is on a distinguished road
Portabote
I have one for about 7 years. Like it very much, it is 8' use 3 HP on it and I am 250 lbs. It will plain. The only two thinks that are draw backs. (1) is the black seats get very HOT! (2) iI you tow it keep a very short painter on it. Or it will be under water.
Old 03-23-2010
erps's Avatar
You're right about the hot seats. I painted the tops white.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 03-23-2010
You do know that you can just use regular oarlocks in the oarlock mounts...that what I do... Haven't used the cheesy aluminum oars in years...
Old 03-23-2010
erps's Avatar
Did you drill out the plastic bushings to accomodate regular oar locks? I've been hesitant to do that but considered machining down a pair of oar locks instead so as to be able to still use the cheesy aluminum oars if I needed to.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
Old 03-23-2010
No, the regular oarlocks I bought at WM fit without any modification.
Stories of towing hard tenders in high seas marujosortudo Seamanship 5 10-26-2009 12:42 PM
A debate on tenders... wildcard General Discussion (sailing related) 16 12-20-2006 08:34 AM
yacht tenders sailingforever Boat Review and Purchase Forum 8 04-18-2006 10:49 PM
nesting dingies vs inflatable kayaks as tenders jbarros Cruising & Liveaboard Forum 3 02-16-2004 10:47 AM
small tenders with class jbarros Gear & Maintenance 2 02-06-2003 04:34 AM
