Old 03-21-2010
weephee is on a distinguished road
Gel Coat
Last fall I ground down my hull from just above the water line to the keel due to blisters etc. and applied 6 coats of Interlux 2000E. I have not applied the anti fouling paint yet. There is a wide black stripe about 3 inches above the water line and originally there was a 2 inch stripe of gel coat just below the black stripe and then the anti fouling paint. I now want to reapply that 2 inch wide gel coat strip that was ground off . Everything I read talks about gel coat repair but I can't find anything on how to apply it as a paint. Do I simply tape off the area and apply like a paint once the hardener is added and then sand and appy again or is there more to it.
Thanks Larry
Old 03-21-2010
ASA and PSIA Instructor
I'd say you are pretty much out of luck, it isn't easy to applay a large coat of gelcoat, and it wouldn't be likely to match the hull very well if you could.
You should not have taken down the gelcoat below the boot-top. You should raise the waterline to the bottom of the Bottom by fairing what's below the bottom, apply some coats of Interprotect for good measure, and then bottom paint.
Old 03-21-2010
Just to be sure that we are talking about the same thing, the area to be gelcoated is 2 inches wide and runs the length of the boat on both sides. The hull will be painted black below the waterline so I need to create a band of white between the bottom paint and this black strip just above the water line. If we are talking the same thing, then you are saying I can't gelcoat that 2 inch strip. If not, can you tell me why not. Not trying to be a smart ass, just trying to understand.
Thanks
Old 03-21-2010
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
can u post a picture? that would be helpful.
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Old 03-21-2010
Gel Coat
The first picture is showing the blue anti fouling paint being soda blasted off
The 2nd picture is showing the bottom gel coat removed
The 3rd picture is showing the 1st coat of interlux 2000E being applied before fairing is done. The last couple of coats of 2000E go up to the bottom of the black band or strip.
I now want to paint or gel coat a 2 inch white strip below the black strip and then paint a black anti fouling paint below the white strip if that makes sense.
Gel Coat-bottom-paint-removal-013.jpg   Gel Coat-hull-repair-018.jpg   Gel Coat-hull-paint-008.jpg
Old 03-21-2010
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Most boats are laid up with polyester resin an cloth. Gel coat is essentially a polyester resin with pigments added.
Most cans of gel coat have labels that read something to the effect that "this product should only be applied on top of another polyester resin".
Interprotect 2000 is an epoxy based barrier coating system. There are some chemical adhesion issues between dissimilar resin based materials.
Personally I would rather use gel coat then painting this small area as it would last much longer then most paints but I am sure it would be much easier just to paint this area with a nice expensive marine paint. The problem with gel coat is that it is not a simple process like painting.
To properly gel coat even this seemingly benign 2" stripe around your hull/freeboard area would entail:
- sanding/fairing the area to be coated, removing most, if not all of the Interprotect 2000 that you just put down there
- wipe area with Acetone and apply gel coat, thinned or straight. Let cure.
- sand the area fair up to 600 or 1000 grit sandpaper
- polish, wax etc
As already pointed out the color will not likely match the rest at first but on your boat that may matter less because of your boot stripe configuration.
There are different types of gel coat products available. Some are pastes and some are more liquid as gel coat is usually sprayed into a mold when a hull is made.
Your boat, your choices, your time and money.
Have fun whatever you choose and be sure to post an 'after' photo of your work.
Old 03-21-2010
Just curious... why did you have them remove the gelcoat before applying the barrier coating. Unless the hull was very wet and had blister problems, which didn't appear to be the case, there was no need to remove the gelcoat. I'd point out that if they had taped off the waterline properly, you wouldn't have this problem.
To gelcoat, you'd probably have to remove the IP2KE, as I don't think gelcoat will stick to it... If you really want a white line between the bootstripe and the bottom paint, you're going to have to paint it IMHO.
Old 03-21-2010
First off, I have no one to blame but me as I did it myself. There were blisters below the black stripe so I ground down anything that was suspect because I didn't want anymore blistering issues. I think I did a good job on that part, maybe too good a job. I didn't know very much about gel coat and assumed I would just reapply it so i guess I screwed up. Sounds like I should just spray in a strip with marine paint and touch it up as necessary each year. I live in Canada so the boat is high and dry each winter and easy to work on Thanks for all your comments and advice.
Old 03-21-2010
pdqaltair's Avatar
pdqaltair is on a distinguished road
From my point of view, one the the reasons we use a boot top stripe is to hide...
...waterline scum. So, why would I want a white stripe there? I would have moved the stripe down to the water, I think. However, what you have is common and no doubt looks good.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 03-21-2010
CalebD's Avatar
Tartan 27' owner
Don't blame yourself. It's fobodies nault and stuff happens.
I applied a gel coat coating to a fairly small epoxy repair (3" x 12") and it is still holding after 5 years. I did this before I read all the fine print on the labels however.
The original gel coat on my boat is 43 years old and from 50' looks fine but it is crazed with spider web cracks when viewed up close.
We all have our problems.
Good luck.
Gel coat blisters superiorvoyager Gear & Maintenance 52 10-25-2010 03:08 PM
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 2 01-17-2010 08:52 PM
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
Gel coat cracks seac Gear & Maintenance 3 12-13-2002 05:46 PM
Gel coat vs epoxy for hull dpoperngr Gear & Maintenance 6 10-28-2002 11:48 PM
