-   -   keel bolts (http://www.sailnet.com/forums/general-discussion-sailing-related/63156-keel-bolts.html)
Eleuthera1 03-22-2010 10:58 PM
keel bolts
Hi
I would like to know if anyone knows were to get Galvanized keel bolts made for my 1951 John Alden ketch,
sailingdog 03-23-2010 09:42 AM
It would help if you said what diameter, length and thread pitch the bolts were.
Eleuthera1 03-23-2010 12:07 PM
Hi
All I know are they are 1 inch galvanized bolts with a tapered head, The plans I have dont give any more detail and they are in German, Im looking for a reputable machine shop that once they are removed I can send them too and have new ones made.
sailingdog 03-23-2010 12:36 PM
Where are you located? If you're in Tahiti, the suggestions I have won't do you much good. :D One machine shop that I'd highly recommend is the Pungo Machine Company in Pungo, NC. They were very helpful when I had to re-build a sail drive leg on a recent delivery trip. :D
RXBOT 03-23-2010 03:11 PM
If the plans are in German the boat may have been built in Holland or Germany and bolts may be metric. Does not matter as any good machine shop anywhere in the world can replicate if given a bolt or drawing of same. You might consider using bronze as a material so you eliminate galvinizing.
sailingdog 03-23-2010 03:43 PM
One issue with going with bronze, it is weaker and more fatigue prone than steel IIRC.
Eleuthera1 03-24-2010 01:30 AM
keel bolts
Thanks for the info, plans are in German but only give diameter, I will have to remove to get the exact length, She has a cast iron keel so I will be sticking with Galvanized bolts
Claud
Eleuthera1 03-24-2010 01:39 AM
I live in Tahiti and we have some good machine shops but no galvanizing facilities, so looks like a State side project.Do you have an email address for Pungo machine company?
Jeff_H 03-24-2010 07:00 AM
You might consider using replacing the bolts with monel, which may be cheaper and easier and be a far superior metal than trying to get a machine shop in the States to produce the bolts and galvanize them. Also New Zealand and Australia may be closer and cheaper as well.
sailingdog 03-24-2010 07:16 AM
Here's their contact info, but I'd second what Jeff said about NZ and Australia possibly being closer and cheaper.
Pungo Machine, Inc.
P.O. Box 188
25468 U.S. HWY 264 E
Pantego, N.C. 27860
1-800-729-6313
252-943-6363
Fax: 252-943-2605
Email sales@pungomachine.com
Business Hours: Weekdays 8:00 a.m. to 4:30 p.m. EST.
