03-26-2010
Take the cushions out of the boat and spray them liberally with KO. This will kill and destroy all the mold/mildew/spores on the cushions.
From Peggie Hall on this subject:
Buy some Raritan K.O. (it's a bio-active holding tank treatment that also "eats" mold and mildew. Saturate the cushions with it--not dripping wet, but enough to make sure it gets all way into the middle of the cushion--and leave 'em out the sun all day. The combination of sunlight and K.O. will leave 'em smelling fresh as daisies. While you're at it, do the same thing to all your musty life jackets and foulies.
BTW, don't use an ozone generator. It contributes to pollution and really won't work unless it is strong enough to cause damage to the plastic and rubber parts on your boat. The "ozone generators" most people use are good enough to cover up odors but do little to eliminate the sources of the odors and the odors return as soon as they're turned off.
