*&%&$#ing Leak! - Page 3 - SailNet Community
post #21 of 21 Old 03-30-2010
vagrant
bobwebster's Avatar
Here are a few novel ways I've managed to get water into our boat:
1. Overfill the freshwater tank. Most of the the overflow goes overboard, but a loose fitting let some into the bilge.
2. Shower drain / gray water loose fitting let water into the bilge when it the gray water tank filled up.
3. Bad window caulk -- rainwater ran down into the bilge from a salon window.
4. A small crack in the cockpit let rainwater into the engine room / bilge.
5. A hose with a spiral wire reinforcement had the spiral wire rust and leak water occasionally at the hose clamp.
Give me a few months and I'll likely discover some more.
bobwebster is offline
rain leak in MacGregor 26x newuser Gear & Maintenance 9 06-10-2015 11:54 AM
Source of Weeping leak into bilge? maybe? GlacialEratic Gear & Maintenance 17 03-26-2010 10:07 PM
oil leak advice marinoinPV Diesel 7 01-02-2010 12:25 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 01:41 AM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 09:00 PM
