Sealing Thru Deck Hardware - Page 2 - SailNet Community
post #11 of 19 Old 03-30-2010 Thread Starter
Ok, I bought the butyl tape 1 inch x 1/8 inches. It comes in a roll with paper on one side. I assumed the paper was removeable but it doesn't come off. Question is should the paper come off and if not do I put sticky side against the deck with the paper side up and then lay the hardware I am sealling on top of the paper and bolt down. Also this stuff sticks like snot. What do I use to clean up. Thanks
weephee is offline
post #12 of 19 Old 03-30-2010
Just a Member
primerate84's Avatar
Cool it down first. Basically, get a cooler with some ice and put the roll of tape in it. Once it is cooled, it will allow you to easily peel the paper off without it adhering to the butyl.
primerate84 is offline
post #13 of 19 Old 03-30-2010
Maine Sail's Avatar
Paper should come off. You can not install it with the paper still on it... Call the dealer and ask if they have had this problem before..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #14 of 19 Old 03-30-2010
Glad I found Sailnet
Bene505's Avatar
I saw Maine's excellent instructions. Is the butyl tape used as a sealant in some way? I think of tape (duct tape, Scotch tape, masking tape) as more of a fabric with sticky stuff on it.
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #15 of 19 Old 03-30-2010
Send a message via Yahoo to dacap06
Brad,
Butyl tape is a sealant all right, but it isn't really tape. It is really more like a mastic and has the consistency of well chewed gum (well, minus the saliva). It does not harden but instead remains flexible and sticky its entire life. That way it flexes with the hardware and deck.
You can tear it and shape it with your fingers. SD advised me to use it when I refinished my grab rails, and it was great advice! I shaped a little of it into a skinny earthworm and used that to fill the countersink area. then I would press some on the bottom of the wood to form a flat area. When I tightened down the bolts, the excess squeezed out, which I then trimmed off with a plastic knife. Ever since it has been dry as a bone inside the cabin all last Summer even with the thunderstorms, and all Winter too despite having 2 feet of snow melting off of the cabin top.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #16 of 19 Old 03-30-2010
Courtney the Dancer
jrd22's Avatar
It's called tape because it comes in a roll generally, with paper separating the rubber. Home Depot sells it around here.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #17 of 19 Old 03-30-2010
Maine Sail's Avatar
You're lucky if HD sells it. The only stuff I have seen at HD around here is butyl foam rubber which is not the same..
______
post #18 of 19 Old 03-30-2010
Glad to help.
Originally Posted by dacap06 View Post
Brad,
sailingdog is offline
post #19 of 19 Old 03-31-2010
Courtney the Dancer
jrd22's Avatar
I was surprised to see it too. Not sure if their stock varies regionally or not (we are in the PNW). It was the butyl tape, 1" by about 1/8" thick , not foam.
John
SV Laurie Anne
jrd22 is offline
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
