Old 03-29-2010
weephee is on a distinguished road
Sealing Thru Deck Hardware
I am embarassed to even ask this question but it is very important to me. I have started removing some of the hardware on my deck that is leaking. One piece in particular is the chain plate opening. I have sealed around it with no problem but there is a cover plate with 2 bolts securing it. The cover plate is cosmetic and does not need to be sealed but how do I seal the bolt holes. If I apply sealant to the holes and then insert the bolts, I have basically pushed all the sealant out of the holes and ended up with sealant all over the threaded part of the bolts. I know this seems like a basic silly question, but I need to be assured everything is properly sealed. Is there a trick to sealing thru bolt holes. Perhaps I should use rubber grommets? Thanks
Old 03-29-2010
jrd22's Avatar
Courtney the Dancer
Bolts (threads,nuts) or screws that just go into fiberglas? If your deck is cored with balsa you will need to pot the holes with thickened epoxy. There should be an excellent post here on how to do all of this by MaineSail, might be a sticky in maintenance. Do a search, should be able to find it.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 03-29-2010
Thanks jrd22. It sounds like Butyl tape is the answer. Only question is what thickness do I want. I will ask that on another topic. Thanks again
Old 03-29-2010
mackconsult is on a distinguished road
Use 5200, although getting things back off after using this can be very difficult.
97 XR600R Honda Dual Sport Motorcycle
98 18' Avon RIB w/ 90 HP 4 stroke Yamaha
95 TDI Passat VW Wagon
05 2500 140" sprinter van w/ v3 frybrid kit
08 Laser Pro #194171
Sail Smart, Sail Hard, Then think about Sailing Fast !!!!!
Some day I will sell everything, buy a 50 ft sailboat, and turn left at the Columbia River Bar
Old 03-29-2010
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
This qualifies as an understatement. With all due respect to Mack, 5200 is a poor choice. Butyl tape is likely the best option. As with most jobs, proper prep is important.
Maine Sail's step-by-step pictorial is exceptional -- check it out.
Old 03-29-2010
Great Porfin. Where do I find Main Sails step by step. Thanks
Old 03-29-2010
The trick is to countersink the fastener holes slightly. This allows some sealant to form a nice little o-ring.. The holes should be properly potted, as seen on Maine Sail's photo site.
Old 03-29-2010
Thank you Sailingdog. I appreciate your help.
Old 03-29-2010
Hopefully just one last question on this. I found a supplier of Butyl tape at a nearby RV park. Do I want the 1 inch wide x 1/4 inch thick tape or the smaller, thinner 1/2 inch wide x 1/8 inch thick.
Thanks again
Old 03-29-2010
Maine Sail's Avatar
You want as thin as you can get. I find 1/2" X 1/8" is the one I use most. 1" X 1/8" would also be good..
Oh and use gray or white not black...
______
-Maine Sail / CS-36T
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
