04-01-2010
dborck
This reply isn't directed at you but more of a general comment.
I can't count the number of times I have seen boats come into harbour with the jib put away and the main covered up, I shake my head every time. Keep your sails at the ready at all times, more your jib than the main as it can be more easily spilled of wind when needed.
I can't count the number of times I have seen boats travel parallel/between 2 piers , more often than not close to the down wind pier. No room to maneuver when things go bad.
As to the engine dieing am I correct in saying that more often than not once an engine is running and warmed up, it's chances of dieing are slim. In other words an engine that will not start is more likely than an engine that will quit once warmed up? It has been mentioned here that bad gas has caused engines to die, fair enough. Was this truely bad gas or a filter system that has not been maintained as much as it could be. Again I am not trying to direct that comment at anyone just a general question to the masses.
I have had to sail the boat in under sail several times due to a engine that was troublesome to start. The cause of my troubles? Me
First time was a bad/weak electrical connection that I knew about and ignored for too long.
The second time, my engine needs it's valves adjusted once a year, again I had neglected this. After safely tie'ing up to my slip I adjusted the valves and the engine fired right up.
As to oars? don't know but I suspect a good handheld VHF and a vigilant marina staff will go further than oars.
John
p.s I have a contessa 26, about 5400 pounds dry weight, I can't imagine a set of oars that would be useful in anything more than zero wind conditions, with that said I have never tried so I could be proven wrong.
