04-07-2010
The winch might be able to handle it... but is there a point on the boat that can handle that load???
Originally Posted by tager
Why not winch it? You would only need something that could winch 4000lbs up a 30 degree slope. I am guessing that the angle of inclination is 30 degrees, right? If the angle of inclination is sixty degrees that ramp is insane!
Even the cheapest warn winch could handle it easily at 9000 lbs pull. I mean, you should just sail the boat to SC, and pick it up on the travel lift. Might be easier than finding someone with a truck and futzing around at the ramp.
