Old 04-08-2010
Wyatt6969 is on a distinguished road
Prop Size
Can someone tell me what size prop I need to put on my 1974 Morgan 27 or 28. It is an OutIsland It has a 18 hp westerby in it and the prop is missing. Any advice will be appreciated.
Thanks, Wyatt
Old 04-08-2010
IT would really help if you said what the transmission gear ratio is as well... with out that piece of information, can't make any recommendations.
Old 04-08-2010
I havent a clue what the gear ratio is
Old 04-08-2010
If you look at the engine/transmission, it will likely have a label that has important information like the model of the engine, which is likely a Westerbeke, rather than a Westerby... which isn't a make of diesel engine AFAIK. It will also have things like the HP rating of the engine and the engine serial number as well as the transmission gear ratio.
You can see the label on this photo of a Westerbeke engine, just right of the bronze water strainer, silver and black on the top of the engine:
Prop Size for Perkins 4-108 KeelHaulin Gear & Maintenance 6 11-22-2009 03:58 AM
Good Prop Size for Express 30 wstewart SailNet Website Technical Support 1 02-10-2007 01:38 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
what size prop?? stevfran Gear & Maintenance 1 01-30-2003 07:16 PM
Proper Prop size for Cat 30 gfeier Gear & Maintenance 0 08-20-2001 04:52 AM
