04-10-2010
A Sea (See) Shower
Easiest way to conserve the fresh water is to get wet (see the shower), shut off the water, lather up, rinse, repeat if necessary. I don't see any benefit (and there are several hygienic drawbacks) to collect and reuse the wastewater from the shower stall - gray water or not.
I have designed recycling systems that collect wastewater, treat it to a fairly high level, disinfect it, then recycle the treated water as flush water makeup to toilets and urinals. It is only cost effective when you have an application such as an office building, sporting venue, or similar non-residential type situation in which the largest wastewater sources are toilets/urinals. Overall discharge can be reduced up to 95%.
And don't forget the George Castanza factor . . .
