04-12-2010
Non-Toxic anti-freeze wouldn't damage the tank AFAIK and would not be too much of a problem for the environment, within reason.
Originally Posted by Claudia1002
Apparently the valve that keeps it shut leaks which would leak antifreeze into the water.
Originally Posted by PeterSailer
The tank is probably made for water, antifreeze might damage it?
